Multiple dash lights
Discussion in 'Electrical' started by Blackcloud, Oct 30, 2024.
  1. Oct 30, 2024 at 12:00 PM
    Blackcloud
    Blackcloud [OP] New Member
    Hello Jeepers!
    I had a problem with my 2014 Patriot not starting so I did a few ‘simpler’ things like checking relays and ignition switch before finally replacing the starter which solved that issue. While working on the ignition switch, the anti theft module came apart and I broke 2 tiny wires inside it. I resoldered them best I could and put it all together. The car runs great now but I have a ton of lights such as engine, traction, 4wd, and antilock brakes on. Could it be the antilock module causing this or did I do something else wrong?
  2. Oct 30, 2024 at 2:04 PM
    Back tracking everything you touched, broke/repaired would be my first step. Assuming you disconnected the battery before making repairs scan for any engine codes that may be reflective of the warning lights on the dash. I'm not familiar with the anti theft module but a new one might be the solution or at least remove a variable.
