Multiple Misfires
Discussion in 'Cherokee' started by saf, Sep 17, 2017.
  1. Sep 17, 2017 at 12:29 PM
    saf
    saf [OP] New Member
    2003 Jeep Grand Cherokee 4.0
    Code gives multiple misfires. Engine light on. When it begins to flash, Engine loses power, I turn it off it will run fine again for a while. Its like it resets even though engine light remains on. Have replaced: spark plugs, coin rail, crankshaft censor and cam shaft sensor. Problem can go months without any issues after a part is replaced. Been dealing with this for about 2 years now. Any Ideas?
  2. Sep 17, 2017 at 5:22 PM
    welcome to the site! I would start with checking the battery cables to make sure they have clean, solid connections.
  3. Sep 17, 2017 at 5:34 PM
    Welcome! Two years not two months? What's the code or have the code identified with rented/purchased code reader.
  4. Sep 17, 2017 at 7:15 PM
    Welcome to the forum. ^^ what chris4x4 and aggrex said.^^. Good place to start.
  5. Sep 18, 2017 at 2:46 PM
    saf
    saf [OP] New Member
    We have checked all battery terminals and replaced battery also. And YES 2 YEARS!! :( Code from O'Reilly's is Multiple Misfires.
  6. Sep 19, 2017 at 9:04 PM
    Jeepmechanic2003
    Jeepmechanic2003 Member
    David
    Grand cherokee
    Stock for now
    Check the body grounds from engine compartment sounds like loose or broken wire
  7. Sep 20, 2017 at 9:19 AM
    Have you replaced the coil packs or spark plugs?
  8. Sep 20, 2017 at 9:23 AM
    Can you give us the actual code?
  9. Sep 20, 2017 at 9:30 AM
    Going to guess p0300.
  10. Sep 20, 2017 at 5:01 PM
    If Prerunner is correct (P0300) then some DIY things to check might be coil, ignition module, fuel pressure, EGR
  11. Sep 21, 2017 at 5:14 AM
    That's a big IF I know..... :confused:
