My jeep keeps cutting off on me when the temp gets to about half point.
Discussion in 'General Jeep Discussion' started by elpinchewey, Oct 9, 2017.
  1. Oct 9, 2017 at 9:37 AM
    elpinchewey
    elpinchewey [OP] New Member
    01 jeep grand Cherokee Laredo
    my jeep keeps cutting off for on me at about half temp.it seems to turn off when I'm stopped but it has turn off once while I was driving. 2001 Jeep grand Cherokee Laredo any ideas on what it might be? I got the crank shaft sensor replaced. But it still does it.
  2. Oct 9, 2017 at 9:53 AM
    Welcome! Any other symptoms or behavior you can identify?
  3. Oct 9, 2017 at 10:46 AM
    elpinchewey
    Somtimes I'll notice if I tap the gas just a little it will keep accelerating for a quick second and then stop. But that's about it
  4. Oct 9, 2017 at 10:48 AM
    Are you saying that when you start up and start driving after a few minutes it stalls. Does this happen everytime? Do you have a check engine light. Pull the codes it should tell you. Codes can be read for free at most autoparts stores. Sounds like you have a bad sensor: cam, crank, or temp most likely.
  5. Oct 9, 2017 at 11:08 AM
    elpinchewey
    Yes I have a check gauges light on.
  6. Oct 9, 2017 at 11:10 AM
    Can you have the codes read, and post them for us?
  7. Oct 9, 2017 at 11:42 AM
    elpinchewey
    I'll try when I get off work
  8. Oct 9, 2017 at 6:23 PM
    Welcome to the forum.
    Yeah, curious as to what the issue might be. You came to the right place.
