My wife's 2007 Wrangler Sahara's rear wiper doesn't work, Help Please!
Discussion in 'Wrangler JK (2007-2017)' started by dtcme99, Oct 2, 2022.
  1. Oct 2, 2022 at 6:10 PM
    dtcme99
    dtcme99 [OP] New Member
    Danny
    2007 Jeep Wrangler Sahara
    Stock
    Fuse is good.
    Hardtop I believe is original equipment. Just purchased it.
    Any troubleshooting ideas would be appreciated.
    Thanks,
  2. Oct 3, 2022 at 7:33 AM
    Dirty Dog
    Dirty Dog Well-Known Member
    Mark
    2011 & 2013 JKU Rubicon
    Time to break out the multimeter. Your problem is most likely the switch, but the wiring and wiper motor are also possible. So start checking. Do you have power to the switch? When you twist the switch, does power come out? There's a disconnect at the rear, so you can remove the hardtop. Is there power on both sides? Is there power to the motor?
    dtcme99[OP], aggrex and LYFZGOOD like this.
  3. Oct 3, 2022 at 8:12 PM
    dtcme99
    Danny
    Stock
    Any way to get a wiring diagram with connections? Need to confirm wire colors and location.
  4. Oct 4, 2022 at 8:14 AM
    Dirty Dog
    Mark
  5. Oct 28, 2022 at 7:25 PM
    dtcme99
    Danny
    Stock
    Thanks. I just got time to look at what you sent me. Hope to take a look tomorrow and see what is wrong.
  6. Oct 29, 2022 at 4:10 AM
    If you can confirm 12V power with a multi meter at the final connector with key in that’s a good sign then move onwards to the motor
