Nasty Hole in the Floor;Best Way To Patch?
Discussion in 'CJ' started by Cheftao, Jul 26, 2020.
  1. Jul 26, 2020 at 4:14 PM
    Cheftao
    Cheftao [OP] Active Member
    Thomas
    1966 CJ 5 with V6 Dauntless
    2 inch lift kit
    Hello Again...
    So now I am onto the floor repair. Both sides of the Jeep foot wells are like this. The drivers side has not been revealed yet, but I’m sure its basically the same. When I removed the old nasty carpet, I used acetone to remove the glue and Lo and behold, a whole bunch of bonds came loose because of the acetone. So my question is: What is the most effective cost sensitive way to fix the hole so I can continue my build? It’s not a show car, but a beach buggy. Give me hope.....
  2. Jul 26, 2020 at 6:22 PM
    Either weld a replacement piece of sheet metal in or bolt in a piece purchased from a local home improvement store. Cut out a pattern that you can replace as simple as you can. You might want to get a bid from a local body shop as a first consideration. You could look at one of the big box 4wd outfits online for body replacement parts or maybe a Jeep junkyard to cut you out a piece. Start your research online.
  3. Jul 26, 2020 at 6:49 PM
    I would go with replacement parts if available!!
  4. Jul 27, 2020 at 6:44 AM
    Cheftao
    Thomas
    2 inch lift kit
    OK thank you both for your response. I’ve checked around for replacement floor pans but no luck yet. I’ll keep you posted
  5. Jul 27, 2020 at 8:45 AM
    Ok well if you can’t find replacement floor pan parts what I have heard done here in West Virginia is stop a sign works pretty good :anonymous::notsure:
  6. Jul 27, 2020 at 8:50 AM
    Probably could get some sheet metal cut over-sized to the rusted areas and rivet them on until you find someone that can weld. Knock off or cut the damaged areas off and arrest the rust. Make a couple of sealable drain holes and you should be GTG.
    LYFZGOOD likes this.
  7. Jul 27, 2020 at 8:51 AM
    That’s probably a better option
  8. Jul 27, 2020 at 8:52 AM
    Done something similar many many years ago when I find them knocked down on the road. The alloy doesn’t rust easily and takes a beating too.
  9. Jul 27, 2020 at 3:00 PM
    Jamesccreasman
    Jamesccreasman New Member
    Sheet metal with pop rivets and the use bed liner spray to seal it...$40.00 project
  10. Jul 27, 2020 at 3:30 PM
    Cheftao
    Thomas
    2 inch lift kit
    Excellent!! Thank you all for your comments and suggestions. I do find the stop sign an attractive option. I have a piece of galvanized kicking around. Any issue using galvanized if I plan on riveting?
  11. Jul 27, 2020 at 4:04 PM
    Nope just cut an over-sized sheet of galvanized metal to the proper shape, bend, drill then rivet it on. Wouldn't hurt to seal against moisture intrusion.
  12. Jul 27, 2020 at 4:05 PM
    Actually, galvanized metal is a great plan as it has a zinc coating. The rivet plan does sound good but they can pull apart during metal flexing. A bolt and nut would be the most secure, but they can be drilled out after the rivet plan fails, if they even do.
  13. Nov 12, 2020 at 4:43 PM
    Cheftao
    Thomas
    2 inch lift kit
    I’m finally finished. Here is how it came out.
  14. Nov 22, 2020 at 6:46 AM
    Justanotherjeeper
    Ontario, Canada
    2024 4xe Rubicon
    Good enough as it is
    Hi Cheftao, it looks fine! Where I live, rust is King, and we see lots of vehicles just like that and much worse. I live outside the greater Toronto area, in small town central Ontario, in a snow belt. Anyone doing this kind of work needs to watch Fitzees Fabrications on YouTube. Btw, Fitzee is a real guy, and typical Canadian, in his case from Newfoundland. His videos are the gold standard for rust repair. You’ll know what I mean when you start watching them. No fancy tools, or fast talk. No slick, expensive after market panels. Just plain simple, excellent repair.
