Need help with Brakes
Discussion in 'General Jeep Discussion' started by North, Feb 15, 2017.
  1. Feb 15, 2017 at 5:55 PM
    North
    North [OP] New Member
    Hey everyone new to the forum.
    Was told that I need to get new brake pads, but they couldn't tell me if roaters needed to be replaced so I thought I would just get pads and then either get new roaters or have them resurfaced...
    Also was told that I had some leakage in my struts which needed to be looked at in the future...
    Looking to purchase the parts myself to save a few dollars and after doing so research everyone keeps telling me to go with EBC greenstuff 7000 in the fronts and 6000 in the back...
    What is eveyones thoughts on pads?
    Thoughts on all this for saving a few bucks to just go with pads and possible new roaters or have them resurfaced?
    Thanks for your help!
  2. Feb 15, 2017 at 6:19 PM
    Welcome! What kinda of Jeep?
  3. Feb 15, 2017 at 6:25 PM
    North
    I have a 2011 jeep grand Cherokee Laredo
  4. Feb 15, 2017 at 7:01 PM
    The basics. If your jeep is stopping fine with no pulsing in the pedal just change the pads. No new rotors. Don't resurface them. If you are feeling some pulsation when you come to a normal complete stop just have them turned.
    If your jeep is riding fine. I wouldn't replace the struts.
    Brake pads: I like Wagner Thermoquiets or Wagner OEX. I get them at Oreilly's. They are ceramic and have low almost invisible break dust. They are a little pricey, maybe $80. If on a budget get Oreilly's brake best selects. They are also ceramic and will probably be less than $50 for the front.
