Lower hose keeps getting loose at the water pump
Discussion in 'Cherokee' started by Jdb1288, Sep 11, 2019.
  1. Sep 11, 2019 at 3:16 PM
    Jdb1288
    Jdb1288 [OP] Member
    John
    1996 Cherokee
    Hi I own a 96 Cherokee that is truly a great ride. However recently my lower hose keeps getting loose at the water pump. Radiator was replaced in july with new hoses, and I replaced the water pump this week. The hose has come loose three times. It does not overheat there is no milkin my oil. Actually the temp is perfect, really leaks most when I park the vehicle. Please help me I am losing my mind thanks
  2. Sep 11, 2019 at 3:19 PM
    Hello John, welcome from Oklahoma.
    You might replace the hose clamp, if it is tight the hose shouldn't be coming loose so it would appear either the hose clamp isn't being tightened enough or it is malfunctioning and becoming loose.
  3. Sep 11, 2019 at 3:22 PM
    Jdb1288
    Jdb1288 [OP] Member
    John
    1996 Cherokee
    Thanks I hope that does it I was also thinking of adding another clamp. Clamp was real loose first time I saw it. thought I did a good job tightening it maybe not.
  4. Sep 11, 2019 at 3:27 PM
    Welcome @Jdb1288 ...hoses generally don't slip off unless the clamps haven't been properly tightened (too loose or too tight damaging the hose). Inspect the outlet at the waterpump for scum/slime/dirt and make sure to place the clamp further up on water pump outlet
  5. Sep 11, 2019 at 7:02 PM
    Welcome to the forum @Jdb1288 . Awesome advice posted up top. How you making out?
  6. Sep 12, 2019 at 7:37 AM
    Jdb1288
    Jdb1288 [OP] Member
    John
    1996 Cherokee
    Thanks for the advice. I replaced the clamp this morning and added another one. Jeep runs great will see over time if that's the fix. Could I have a bigger problem?
  7. Sep 12, 2019 at 12:47 PM
    scs_vuth
    scs_vuth Member
    Vuth
    Bay Area
    2017 Wrangler Unlimited Sport
    Try one of these constant tension clamp. It will expand and contract with your radiator temp.
  8. Sep 12, 2019 at 1:40 PM
    I don't imagine there would be any underlying problem with a hose coming off, unless perhaps somehow the hose was replaced with an incorrect hose of a larger size.
  9. Sep 12, 2019 at 2:42 PM
    Jdb1288
    Jdb1288 [OP] Member
    John
    1996 Cherokee
    I am going to get two of those clamps and a new hose thanks very much for the advise
  10. Sep 12, 2019 at 3:19 PM
    A new lower hose, the clamp above is a great design, think about a new radiator pressure cap.
