No heat on drivers side/ Air blows on and off when started
Discussion in 'Grand Cherokee' started by Nated0323, Sep 5, 2024.
  1. Sep 5, 2024 at 12:46 PM
    Nated0323
    Nated0323 [OP] Active Member
    So I recently bought a 2011 Jeep grand Cherokee 70th anniversary with 100k. The first thing I noticed was after I would start up the Jeep the air would blow full blast for one minute then it would stop for 6 seconds then automatically come back on full blast for one minute, etc. It does that on and off about four times for a total of 5 minutes. Then works fine till the next time the car is turned off/on. The next problem I noticed is there is no heat on the drivers side vents no matter what I set the temperature at it only comes out as outside temp. The knob used to go from feet to head to defrost works fine, just no heat. Passenger side works perfect. Any help would be greatly appreciated
  2. Sep 8, 2024 at 4:24 AM
    MackDogDiesel
    MackDogDiesel Member
    Paul
    2019 sting gray grand cherokee
    Steel front bumper, all terrain aggressive tires, side step rails, class 4 receiver with dual American flag mounts, roof rack, 10 LED light bars, rock lights, master control switch board, American flag decals, 2 inch lift, 2 inch spacers, slotted rotors.
    This could be 1 of 2 things.
    1. A/C Control switch is faulty and it's only working on a few settings and not all. Chances are that if you were to pull it out and check the connector. If both the connector and Control switch looks burnt, both connector and switch MUST be replaced.
    2. The heater Control vent valve ended up failing making it not properly channel through the correct setting.
    Personal experience: flush your heater core. Since it's a 2011, it would be wise and wouldn't hurt. Gunk does build up over time and can seize your heater core valve giving you only 1 setting. Just so God for bid after you replaced either one, and then your heat stops working. Now you need take everything apart again and it's just a hassle.
  3. Sep 8, 2024 at 1:30 PM
    Nated0323
    Ok thanks for the suggestions. Do you think both issues are related, the no heat on dr side and the blower on/off??
  4. Sep 8, 2024 at 3:44 PM
    MackDogDiesel
    Paul
    Yes! The control switch opens/closes the vents would be the issue at hand.
  5. Sep 10, 2024 at 11:36 AM
    Nated0323
    Ok thank you for the suggestions. I’ll post back with updates
  6. Sep 12, 2024 at 7:20 AM
    I’m guessing you have a vacuum leak I had the same issue mine was a vacuum line ran underneath the battery.
