No heat with 2007 Grand Cherokee
Discussion in 'Cherokee' started by Jne2024, Feb 23, 2024.
  1. Feb 23, 2024 at 5:45 AM
    Jne2024
    Jne2024 [OP] New Member
    Joseph
    2007 jeep grand cherokee 3
    7L V6 4 wheel drive
    Here's the symptoms
    :-The heat does not work.
    -The fan is blowing, the fan speed is adjustable and blows.forcefully, just Cold.
    -Slow to warm.up
    - Heat blows cold air no matter where you set the temperature Guage.
    - Car never overheats.
    -Engine temperature, appears.normal, never to high never to cold.
    -Replaced.drivers side blend door actuator.
    -Replaced thermostat
    -Topped off antifreeze
    -Tried briefly reversing the tube's going to heater core, in an attempt to blowing any potential.blockage out.
    - I did see gunk on bottom of radiator cap, gel like gunk.
    -No antifreeze smel in vehicle
    - I replaced 1 blend door actuator I'm not sure if there's 2 or not.
    -When car is cold and you start it the radiator hoses BOTH upper and lower suck closed and flatten drastically , like a vacuum is in the system.coolant.system, when the car warms up, that goes away. And the radiator hoses appear normal.
    -This vehicle does.not have dual zone climate control. One setting fir whole car, so I don't believe there is a second blend door actuator.
    ******** WHAT DO II REPLACE NEXT????? ***********
    -I'm fixing this myself, so don't say bring to mechanic.
    -PLEASE TELL ME , WHAT TO DO, WHAT TO CHECK,??
    -THIS IS A JEEP GRAND CHEROKEE LAREDO (3.7L V6 4 WHEEL DRIVE)
    Jne2024@gmail.com
