Noisy fuel pump and no brake lights
Discussion in 'Cherokee' started by Crystalk, Sep 13, 2016.
  1. Sep 13, 2016 at 11:24 AM
    Crystalk
    Crystalk [OP] New Member
    92 Jeep Cherokee Laredo 4x4
    3 inch lift
    My jeep has an excessively noisy fuel pump. I've replaced the isolators on top of the fuel tank, fuel pump and filter, and the regulator that drops it from 12v down to 9v. Still super noisy. I'm at a loss on how to quiet it. Also, my break lights are out. I've replaced bulbs, fuses, and break switch. Can't find any shorts in any of the wiring either. Suggestions with similar experiences would be appreciated!
  2. Oct 2, 2016 at 10:18 PM
    Choppin Trailz 89yj
    Choppin Trailz 89yj Mad hatter
    North central P.A,Tioga county
    1989Black,YJ
    2.5inch Rough Country lift w/ hydrolic shocks. next step 3.75 offset 15 by 8 in rims w/ 32 by 11.50 dick cpeck mt tires
    check your ground wire at rear for lights ? my best guess. .fuel pump unsure could also be the ground issue?? good luck
    Crystalk[OP] likes this.
  3. Oct 2, 2016 at 10:20 PM
    Crystalk
    3 inch lift
    Everything tests fine it sucks I have had jeep mechanics look at it and they don't know either. Do you think replacing the fuse box would work?
  4. Oct 21, 2016 at 4:39 PM
    shumphries
    shumphries Member
    Steve
    2000 Jeep Cherokee 4D 4.0
    None
    If both your brake lights will not work it may be the switch associated with the brake pedal.
  5. Oct 24, 2016 at 12:03 PM
    Choppin Trailz 89yj
    1989Black,YJ
    i would try adding extra ground first not expensive and worth a try ? ? ?
  6. Nov 6, 2016 at 7:06 PM
    Crystalk
    3 inch lift
    I have now replaced the switch again and still nothing.. I'm left with thinking I need to just replace the whole assembly..
    Adding extra ground? How would I do that? I'm not much of a mechanic but if you could tell me how I can do it
