Nutter bypass
Discussion in 'CJ' started by MattLaug24, Sep 30, 2017.
  1. Sep 30, 2017 at 3:02 PM
    MattLaug24
    MattLaug24 [OP] Member
    Matt
    1985 Jeep CJ7 6-258
    hello all, I’d like to do a Nutter Bypass on my cj7, and although there are a meaty helping of videos and articles on it, I did a motorcraft 2100 carb swap on mine, and all the videos show for the stock BBD carb. So I’m curious if anyone knows if there is a different way to do it with my carb, or if a bypass is even necessary. I’m trying to bypass my oxygen sensor ignition control with it. Thanks.
  2. Sep 30, 2017 at 4:51 PM
    The bypass is to get rid of the ecm. If you trash the current coil, distributor, and ignition module, and replace it with a HEI distributor you'll essentially be doing the same thing. You will also see a marked improvement in stable performance.
  3. Sep 30, 2017 at 8:03 PM
    MattLaug24
    Matt
    1985 Jeep CJ7 6-258
    I was considering doing that anyway. Then my question is will it make it so the O2 sensor doesn’t affect the ignition or will I have to still put all my emissions crap back together to make it run right. My O2 sensor is off of my jeep completely right now
  4. Sep 30, 2017 at 8:08 PM
    I'm subbed....all new to me. I'm sure OFFGRID will help me learn some thin again. :hattip:. Thanks for helping out Peter. Hope all is good down there in TX after Harvey gave you guys a visit. :)
  5. Sep 30, 2017 at 10:14 PM
    I have never installed a 2100. I take it straight to TBI. More reliable off road. The O2 tells the carb how lean or rich to run. When you switched to the 2100 did you hook up all of the wires from the old carb to it. I would think that none of the plugs would fit so you left them off, essentially disconnecting the carb from the ecm and O2 sensor. Sometime last spring there was a guy doing the exact same thing as you are doing. He took out the ecm and all associated wiring. Installed a new HEI. He hooked one new wire up wrong and it wouldn't run. It took him a couple of weeks 2 find the issue, but after all is said and done it ran better than ever. It is well documented in Jeeps.net. I will try to find it and post a link here. You should look for it too.
  6. Sep 30, 2017 at 10:16 PM
