Oil sensor
Discussion in 'Cherokee' started by Gen1218, Oct 15, 2017.
  1. Oct 15, 2017 at 9:00 AM
    Gen1218
    Gen1218 [OP] New Member
    Genny
    2001 Cherokee
    My jeep does not mark the oil level on the gauge I change the oil sensor and it still doesn't work any Help will be appreciated
  2. Oct 15, 2017 at 9:31 AM
    Welcome! Can you give us more information? Are you talking about the Dipstick?
  3. Oct 15, 2017 at 9:46 AM
    2oldjeeps
    2oldjeeps Well-Known Member
    98 and 2000 xj's 99wj
    ground the sender wire to check. open wire?
  4. Oct 15, 2017 at 10:30 AM
    Gen1218
    Genny
    2001 Cherokee
    Not the dipstick when I get oil changes or even when I check the oil guage it's always on 0 I was told it was the oil sensor changed it with no luck
  5. Oct 15, 2017 at 4:48 PM
    Welcome to the forum.
    I owned a 2000. I'm not sure where your issue is either. Where are you seeing or reading its showing you a zero?
  6. Oct 15, 2017 at 4:56 PM
    Offroad798
    Offroad798 Well-Known Member
    Florida
    2015 Rubicon
    Here is one way to check the oil sensor, gauge. Ignition to run, unplug oil pressure sender conn from sending unit. Touch conn to engine block ( good ground) gauge should read at low end of scale. When conn is not touching ground (open) gauge should read at high end of scale. If ok sensor bad. If not check wiring between sensor and gauge for open. Repair if you find any problems and if wiring ok bad gauge.
  7. Oct 16, 2017 at 6:30 AM
    Please take a picture of what you are talking about and post it so that we know for sure. Sounds like you are talking about your oil pressure gauge. It measures the oil pressure in the motor. It will stay on "0" if the motor is not running, low at idle, and as your RPMs increase the pressure in the motor will increase. That is what the guage is telling you. It does not measure the oil level, but the oil level does have impact on the oil pressure.
  8. Oct 16, 2017 at 6:06 PM
    Thank you OFFGRID. That was my point. What are you looking at Gen1218?
  9. Oct 17, 2017 at 6:15 AM
    Check wires for the sensor and you might pull the gauge cluster and make sure the gauge is making sufficient contact with the circuit. I don't recall what pins on the cluster connector is for the oil pressure but if you can locate them you can see if signal is getting to the cluster. If you can't figure it out you can get an aftermarket electrical or mechanical gauge.
