One click, sometimes none. Then it starts.
Discussion in 'Electrical' started by Budwiser114, Aug 22, 2021.
  1. Aug 22, 2021 at 6:57 PM
    Budwiser114
    Budwiser114 [OP] New Member
    07 silver Wrangler Sahara
    07 jk.. new starter, battery, relay. Cables good. Sometimes clicks but only once. May have to Retry two or three times.
    Anyone herd of this annoying problem before.
  2. Aug 23, 2021 at 2:40 AM
    one click - I am guessing that is the STARTER solenoid that is clicking and not the starter relay.
    If it is the starter solenoid - a new starter solenoid is on your shopping list, but* you may have to replace starter.
    * Isn't there always a BUT
    Groundfault and aggrex like this.
  3. Aug 23, 2021 at 1:52 PM
    Budwiser114
    Starter and Battery are brand new
  4. Aug 23, 2021 at 2:17 PM
    Inspect the cables a bit deeper and underneath. For a 2007 you might be surprised to see or find decayed cables like my pic FC688BEB-C2C1-4A3F-8A9E-AAF6FBB2408F.jpg
    Groundfault likes this.
  5. Aug 23, 2021 at 2:30 PM
    ok my first suspect the solenoid was wrong, lets confirm its the SOLENOID or the relay is the clicking you hear.
    You ahve checked, cleaned tightened the battery cables both ends?
  6. Aug 23, 2021 at 2:31 PM
    Groundfault
    Groundfault Well-Known Member
    Tim
    87 Wrangler, kind of...
    Always good to double check cables and ground points.
    Auto or manual transmission? Have you tried starting it in neutral instead of park with foot on brake?
