Overheating
Discussion in 'Cherokee' started by TaeeWhite, Oct 22, 2019.
  1. Oct 22, 2019 at 8:48 PM
    TaeeWhite
    TaeeWhite [OP] Member
    Davonte
    2008 Jeep Grand Cherokee Laredo
    Soon to replace the transfer case
    My vehicle is now over heating. And as well as my relay switch for my radiator fan doesn’t go on it’s own. I have to jump it with cables. Does anyone have this same problem?
  2. Oct 23, 2019 at 4:25 AM
    this is a 2008 wk with what engine?
    First thing I would do is check for codes, and check fuses - once we know engine and question of codes we can offer specific advise.
    TaeeWhite[OP] likes this.
  3. Oct 23, 2019 at 7:18 PM
    Items that can cause overheating are a bad thermostat, fan clutch, and not getting the cooling system maintained.
  4. Oct 23, 2019 at 7:33 PM
    Since the electric fans are not activated inspect/replace the relay switch, temp sensors, check for voltage. I'll assume when the fans are jumpered there is no over heating, right?
  5. Oct 24, 2019 at 5:22 AM
    TaeeWhite
    Davonte
    It’s an 4.7L
  6. Oct 24, 2019 at 5:22 AM
    TaeeWhite
    Davonte
    Nah believe it or not it still over heats
  7. Oct 24, 2019 at 5:38 AM
    do you have 2 fans? hyd and elec? Again post all codes as the PCM is involved in fan control.
    Anyway you claim fan forced on and a overheat still - I would confirm fluid level, how did coolant look any evidence of oil in coolant? Look in radiator NOT coolant bottle for inspection.
    Then 1st suspect would be thermostat.
