Paint
Discussion in 'General Jeep Discussion' started by Adam39601, Oct 10, 2017.
  1. Oct 10, 2017 at 12:16 PM
    Adam39601
    Adam
    2001 jeep wrangler sport
    What is the name of the color that Chrysler gave the yellow in the 2001 Jeep Wrangler the factory name I want to get it repainted just need to know the real name color
  2. Oct 10, 2017 at 12:35 PM
    Look for this sticker and you will have the actual color code posted next to the word "Paint" : in this example it is "PV1". This can be found on the left side of the dash as pictured in the second.
  3. Oct 10, 2017 at 12:37 PM
    You should be able to give this color code to any paint store to have duplicated. If you have to have the name just google "color code _____"
