PO330 code
Discussion in 'Grand Cherokee' started by Jrgabriel, Mar 26, 2020 at 6:43 PM.
  1. Mar 26, 2020 at 6:43 PM
    Jrgabriel
    So after having the knock sensors (supposedly replaced) - I’m still getting the Knock Sensor code. I did have the wire harness replaced to fix the P0334 code...
    I am curious if there is another portion of the wiring harness going from the knock sensor to the PCM that needs fixing....
    Or could this fuel pump relay recall problem be causing my whole mess with voltage and all these issues???
    Thoughts or ideas please???
  2. Mar 26, 2020 at 7:13 PM
    Jrgabriel
    Could I just need 93 grade gas!!??
