Power steering pump mounting holes aren't lining up correctly
Discussion in 'Grand Cherokee' started by Tbone1011, Jan 3, 2023.
  1. Jan 3, 2023 at 8:19 AM
    Tbone1011
    Tbone1011 [OP] New Member
    i have a 99’ Grand Cherokee 4.7l AWD.
    I am replacing my power steering pump and the mounting holes aren’t lining up correctly. Yes, I have to right part, it matches all of the replacement power steering pumps for this model.
    what the heck am I missing?
  2. Jan 3, 2023 at 10:03 AM
    Dirty Dog
    Dirty Dog Well-Known Member
    Mark
    2011 & 2013 JKU Rubicon
    Maybe someone did an engine swap in the past?
  3. Jan 3, 2023 at 11:10 AM
    Tbone1011
    Hey man, that is a good question.
    I’ll jot down the engine # and research what year it is. If so, I am completely unaware there was an engine swap prior to my ownership
    Bob and LYFZGOOD like this.
  4. Jan 3, 2023 at 4:08 PM
    Dirty Dog
    Mark
    If it doesn't bolt directly to the block, it could also be that someone decided to relocate the pump for some reason and changed brackets.
  5. Jan 3, 2023 at 8:09 PM
    Tbone1011
    That’s another question I should’ve asked, when I took off the old one, it didn’t have a bracket, should a 99 have one? As far as I can tell it bolts right to the block with 3 bolts and some blue thread locker, doesn’t even seem to have a gasket or nothing
  6. Jan 4, 2023 at 5:20 AM
    Tbone1011
    I think this is the engine # from what I can tell. About to look it up.
    Dirty Dog likes this.
