Radiator Leak
Discussion in 'Wrangler TJ (1996-2006)' started by kyletraci, Dec 7, 2017.
  1. Dec 7, 2017 at 7:51 AM
    kyletraci
    kyletraci [OP] New Member
    Kyle
    2001 Wrangler Sport
    I recently had a new radiator installed in my 2001 Jeep Wrangler and the drain on the bottom leaks from time to time. Is there a way to plug or seal it to keep from buying another radiator?
  2. Dec 7, 2017 at 10:13 AM
    Welcome to the site! Are there any particular conditions when it leaks?
  3. Dec 7, 2017 at 10:18 AM
    Is it still under warranty?
  4. Dec 7, 2017 at 7:01 PM
    Welcome to the forum kyletraci.
  5. Dec 7, 2017 at 7:04 PM
    Welcome! How new is your new radiator? Taken it back to the shop that installed it yet? Sure its not a leak from a different higher location trickling towards the bottom? Try to tighten the radiator drain cock a bit more?
  6. Dec 9, 2017 at 7:42 PM
    kyletraci
    Kyle
    2001 Wrangler Sport
    I am sure it is coming from the drain. I did not know it had a screw. i was told it was spring loaded. I am going to wipe it clean and try to tighten it. I will reply to let everyone know how it goes.
