Raw fuel smell
Discussion in 'Wrangler JK (2007-2017)' started by detroitjeep, Aug 1, 2021.
  1. Aug 1, 2021 at 6:08 AM
    detroitjeep
    detroitjeep [OP] New Member
    2013 jk sport
    Jk with 3 half inch with 37 inch tires
    My 2013 jk had I raw fuel smell when with no codes what could it be
  2. Aug 11, 2021 at 9:53 PM
    Groundfault
    Groundfault Well-Known Member
    Tim
    87 Wrangler, kind of...
    Just noticed your post. Hopefully you've already solved problem. Gas smell in exhaust is a sign of a bad air/fuel mix. un-burned gas. Lots of computerized crap that can cause that, but anything too far out of spec should set CEL. First thing I'd do is pull the plugs and see if any are fouled black with carbon. Potentially a leaking injector.
    Could be it's not getting good spark on all. clinders jand ust needs new plugs, plug wires and a tune-up. Let us know if you figure it out.
  3. Aug 12, 2021 at 2:32 AM
    wow how did this fall thru the cracks - not seen without giving a suggestion..... IDK
    Anyway some thoughts.
    A one time event or on severl ocassions?
    DO not 'top off" tank, when gas hose clicks off your done.
    A thought HOW do you know there is no codes? Being a tech I am anal about scanning...we love our scanners-
    I will try to remember to check for any TSB's later today. Doubt it but WTF friends drive jeeps.
    Groundfault and aggrex like this.
  4. Sep 27, 2021 at 7:26 PM
    monkey_boy5
    monkey_boy5 New Member
    2010 Jeep Wrangler
    18" Wheels
    I have had this for the past month but have the P0456 Small evap code. Have replaced canister, purge valve, and ESIM but sometimes smell gas on passenger side.... I think it is small leak in fuel pump from researching.
  5. Sep 28, 2021 at 3:30 AM
    EVAP leaks are going to require a "smoke machine" yes you could take a GUESS and replace gas cap*, hoses, components SHOTGUNNING its called.
    * OEM is suggested - aftermarket is not always the same.
