Rear Cargo Door Vent Question
Discussion in 'Wrangler JK (2007-2017)' started by Justanotherjeeper, Nov 25, 2020.
  1. Nov 25, 2020 at 3:35 PM
    Justanotherjeeper
    Ontario, Canada
    2024 4xe Rubicon
    Good enough as it is
    Today I removed the spare tire carrier from my project JK and I noticed that one of the vent flaps on the drivers side lower corner of the vent located behind the spare wheel is missing. Is this a big deal? Will this allow backwash water on the highway to enter the rear cargo door? It’s not a big deal to replace the vent, but just wondering if that’s necessary. I could also silicon a small cover over the opening if I need to prevent moisture from entering. I’m sure the vent would still function with one less opening back there. Or, not? Anyone know about this or have any advice?
  2. Nov 25, 2020 at 6:13 PM
    Those flaps probably prevent heavy rain or monsoons from dripping in some rain water while driving. Cut a piece of flexible plastic/rubber sheet and caulk the top edge should do the trick.
    Justanotherjeeper[OP] likes this.
