Rear liftgate lock stuck in lock position while open
Discussion in 'Grand Cherokee' started by Kunta780, May 23, 2023.
  1. May 23, 2023 at 12:53 PM
    Kunta780
    Kunta780 [OP] New Member
    Mike
    2011 Jeep Grand Cherokee
    Rear liftgate lock stuck in lock position while open. Cannot close.
  2. May 23, 2023 at 1:46 PM
    Get a small flat blade screw driver or pick and try to move the inner latch mechanism on the door. Some WD40 may help to loosen things or the gunk assuming nothing is broken
    LYFZGOOD and Bob like this.
  3. May 26, 2023 at 11:38 AM
    Jeep4Life
    Jeep4Life Well-Known Member
    2012 Jeep Wrangler Unlimited
    Does it lock and unlock with a key or doesn’t move at all? If stuck completely try what aggrex said, but if locks/unlocks with key maybe the automatic locking tab came loose or needs replaced.
  4. Jun 5, 2023 at 10:40 AM
    Justanotherjeeper
    2011 Red Wrangler 2 door
    paid cash for it.
    A photo would help.
    When I bought my Jeep it was a fixer upper, and had been driven in the winters in Ontario, Canada. Road salt had seized up all the locks and none worked, although they were seized to the unlocked position fortunately. I’m no locksmith, but after trying to get them unseized on the Jeep with various elixirs I finally removed one and took it apart. The little tumblers inside the lock cylinder were completely oxidized and frozen. I soaked the disassembled cylinders overnight in rust remover, and gently pressed out each tumbler using the correct diameter machinist’s punch. A small drill bit would work too, using the drill end. I was careful to keep track of the order of their removal as this determines how your specific key pattern moves the tumblers and opens the lock.
    I was successful! It requires patience and perseverance but locks can be repaired. Now all my locks work, and I’m still using the OEM keys.
    You can do it, good luck!
