Rodent?
Discussion in 'Wrangler JK (2007-2017)' started by FloridaJeep, Aug 21, 2021.
  1. Aug 21, 2021 at 5:05 AM
    FloridaJeep
    FloridaJeep [OP] New Member
    Priscilla
    2018 Wrangler JK
    The last two mornings, this pile of foam insulation has been found under the rear passenger side of my Jeep JK Wrangler. I also found a nest with some of this and leaf litter under the driver’s side window cowl yesterday afternoon. I checked underside, there is no obvious foam insulation anywhere under the rear passenger door (just metal components). I checked inside under all the seats, they are intact. I assume a rat is doing the damage, but can’t determine where this is coming from so I can deter further damage.
  2. Aug 21, 2021 at 7:25 AM
    Time to place a few of these traps strategically in the garage and/or in the Jeep before they start chewing those tasty wires within the Jeep. Any mouse droppings around the foam pile?81WUOGwS97L._AC_SS450_.jpg
    tomrr likes this.
  3. Aug 21, 2021 at 7:29 AM
    FloridaJeep
    Priscilla
    2018 Wrangler JK
    Plan to put down some tasty rat poison tonight and a camera.
  4. Aug 22, 2021 at 4:06 PM
    You better use a trap if they eat the poison and go somewhere you can’t get them but you’ll find them pretty easy and that’s not good :facepalm:just my two cents
  5. Aug 26, 2021 at 7:54 PM
    JJS2
    JJS2 New Member
    Jim (Michigan)
    2015 JKU Sport-S Anvil/Black
    Teraflex 2.5 coil lift w/Rancho RS9000s, AEV Bumpers & Tire Carrier, Air Lift bags,
    My '15 JKU has sprayed foam in the rear quarter panels, which I found when I removed the tail lamps to route some wires. I wonder if that might be the source of your white material?
    When I left the Jeep parked outdoors for a week or two last summer, mice developed a taste for the foam insulation under the engine cover. No wire damage, though.
