Roof mounted fog lights wiring
Discussion in 'Lighting' started by BennyWJ, Jun 23, 2017.
  1. Jun 23, 2017 at 12:39 PM
    BennyWJ
    BennyWJ [OP] Member
    Benny
    2000 Jeep Grand Cherokee
    3 inch lifrt
    so i want to install 4 circular fog lights onto the roof of my jeep. i was wondering if i could tap into the stock fog lights from the bumper and wire them there so that all the fog lights can be turned on from one switch and not have separate switches. i already have 2 fog lights from the grill guard tapped into the stock fog lights so could i wire in 4 more?
  2. Jun 23, 2017 at 2:44 PM
    If you use a Relay, you shouldn't have an issue, but if you wore right into the circuit you may burn thebwires, or blow fuses.
    BennyWJ[OP] and aggrex like this.
  3. Jun 23, 2017 at 4:27 PM
    Review the amp draw per light so as not to exceed max rating of oem setup. LED-type auxiliary lighting have low amp draws. Not too sure about fog lights on the roof.
  4. Jun 23, 2017 at 5:51 PM
    BennyWJ
    BennyWJ [OP] Member
    Benny
    3 inch lifrt
    Great. I have fuses connected to the wires on both of my front fog lights. How would the relays be connected?
  5. Jun 23, 2017 at 6:00 PM
    BennyWJ
    BennyWJ [OP] Member
    Benny
    3 inch lifrt
    Bub
    Also i didnt use a relay for the front fog lights. I just connected a fuse to each light. Would i be able to do the same with the 4 roof mounted lights?
  6. Jun 23, 2017 at 6:06 PM
    If it exceeds the current draw of the circuit, it will just blow fuses. Find out how much current, or wattage the circuit will take, then find out how much power you need to supply to the lights.
    OFFGRID likes this.
  7. Jun 23, 2017 at 7:33 PM
    BennyWJ
    BennyWJ [OP] Member
    Benny
    3 inch lifrt
    Each light is 27W. I cant seem to find the wattage for the circuit.
  8. Jun 23, 2017 at 7:36 PM
    Ok....I think the fog light circuit is good for 10 amps draw. At 27 watts, that's about 2 amps each, so about 8 amps for the 4. Plus what you already have hooked up, sounds like your over the limit for that circuit.
    aggrex and OFFGRID like this.
  9. Jun 23, 2017 at 7:45 PM
    FWIW, A friend told me years ago, to try and stay around 50% of the circuits rated amps. I kinda thought this was a little on the "too Conservative" side, and focused more on proper connections. All worked well, until I hit a switch, and magic smoke came out from under the dash. Ever since, Ive learned to tame the magic smoke with a relay, and dedicated power run.
  10. Jun 23, 2017 at 8:20 PM
    BennyWJ
    BennyWJ [OP] Member
    Benny
    3 inch lifrt
    Makes sense. Ill just have a separate wiring harness for the roof lights.
  11. Jun 23, 2017 at 8:24 PM
    Use the fog circuit as the "trigger" for the lights, but run the power, and relay so you can keep the power isolated from the fog circuit. That way you still can have the 1 switch to turn them on.
  12. Jun 23, 2017 at 8:31 PM
    BennyWJ
    BennyWJ [OP] Member
    Benny
    3 inch lifrt
    How would that circuit diagram look like? Where would the relay be?
  13. Jun 23, 2017 at 8:34 PM
    The White Wire would be connected to your Fog Light circuit:
  14. Jun 23, 2017 at 8:48 PM
    BennyWJ
    BennyWJ [OP] Member
    Benny
    3 inch lifrt
    That confused me.
  15. Jun 23, 2017 at 8:58 PM
    Wire the White wire to the Fog Light + Wire, then connect the White and Green together, with the Green wire plugging into the "86" Terminal on the Relay. Wire the "30" connection on the relay to the + on the Battery, and the "85" to a ground. Then, run a power wire to the lights, connected to the "87" connection on the relay. Run the ground wire on the lights to any ground. This way, when you turn on the fog lights, the lights are power directly from the battery, and not pulling the load off the fog circuit.
  16. Jun 23, 2017 at 8:59 PM
    I'll try to look for a pre wired set up in my box-O-stuff. If I find one, I'll send it to ya.
  17. Jun 24, 2017 at 1:58 PM
    BennyWJ
    BennyWJ [OP] Member
    Benny
    3 inch lifrt
    So basically the roof lights will have its own circuit and will only be connect to the switch by the white wire?
  18. Jun 24, 2017 at 9:33 PM
    Yes. The fog light switch will still operate them.
