Rough idle after restarting Cherokee
Discussion in 'Cherokee' started by Mosscountry4x4, Dec 14, 2017.
  1. Dec 14, 2017 at 7:17 AM
    Mosscountry4x4
    Mosscountry4x4 [OP] Member
    Brandy
    99 Jeep Cherokee
    2in lift, fishing pole rack on inside.
    I am about to blow up my Jeep.
    Please HELP.
    I had to replace the torque converter, flywheel, starter, CSP, TPS, Idle air control.
    I can start my Jeep and it will purr like a kitten, shut it off and go to start her back up and she idles really rough.
    Does anyone have any ideas.
  2. Dec 14, 2017 at 9:27 AM
    That's a sign of an ignition coil issue.
    Bob and Mosscountry4x4[OP] like this.
  3. Dec 14, 2017 at 10:32 AM
    Southeast Overland
    Seneca, South Carolina
    Can you give us a bit more info? Stuff like year, how long you leave the Jeep running, temps ETC. The first thing that comes to mind is fuel rail heat soak. Try letting it run turning it off and leaving the hood open while its off to let heat escape and see what that does.
    ~Jeff
  4. Dec 14, 2017 at 1:06 PM
    Are you getting any codes? (check engine light on?)
  5. Dec 14, 2017 at 1:22 PM
    Mosscountry4x4
    Brandy
    99 Jeep Cherokee
    It will throw a code and then it will go away.
  6. Dec 14, 2017 at 1:52 PM
    It's potentially still saved. A cheap OBD2 bluetooth dongle is an excellent tool to keep around. I keep mine plugged in 24/7 and with the torque app can see what the engine and sensors are doing real time. It can scan and clear codes as well.
  7. Dec 14, 2017 at 3:36 PM
    Mosscountry4x4
    Brandy
    99 Jeep Cherokee
    Thank you for all of everyonea help. It was a bad crankshaft position sensor.
  8. Dec 14, 2017 at 4:07 PM
    man...I was way off.....:anonymous:
  9. Dec 14, 2017 at 4:22 PM
    Mosscountry4x4
    Brandy
    99 Jeep Cherokee
    Thats cool. I appreciate everyone's input.
  10. Dec 14, 2017 at 6:51 PM
    Edit. :anonymous:. Me too. But hey. Good you found the fix.
    Mosscountry4x4[OP] likes this.
