So I got a p0430 today
Discussion in 'General Jeep Discussion' started by Billy1234, May 10, 2018.
  1. May 10, 2018 at 2:45 PM
    Billy1234
    William
    2011 jeep wrangler
    None yet
    good ole p0430 code today wanted be the best. Have the converters replaced or say. Screw it and straight pipe it or is there another way around it..... I think I posted this befor
  2. May 10, 2018 at 5:47 PM
    Possible causes
    Three way catalytic converter
    Bank 2 Exhaust Leak
    Intake air leaks
    Fuel injectors may be faulty
    Fuel injector leaks
    Spark plugs may be faulty
    Improper ignition timing
    Engine Control Module (ECM) Dirty air filter
    Billy1234 [OP] likes this.
  3. May 11, 2018 at 3:33 AM
    Billy1234
    William
    2011 jeep wrangler
    None yet
    Thanks as always Chris. Ganna look at all this today after work.
  4. May 12, 2018 at 7:07 AM
    first you cannot use a straight pipe or do away with cat on a registered vehicle. Enough said.
    Then we need to find out WHY the current cat failed - before the second one follows.
    Post ALL codes - use a scanner. Did you have any lately as misfires are cat killers.
    Any engine mods or powertrain BS ? STOCK is best.
  5. May 12, 2018 at 7:09 AM
    Billy1234
    William
    2011 jeep wrangler
    None yet
    I have everything stock and I have had a multiplie cylinder misfire for a few days now but all that is brand new and I straight piped my old car and it passed inspection lol but I know what your saying
  6. May 12, 2018 at 7:13 AM
    If you have a SCANNER - post all data - codes, ECT, FT's. B2S1 B2S2,
    no scanner -
    If driveable have the system scanned at one of the part stores that does FREE scans...
    I do not understand 'all that is brand new" ? misfire is new?
  7. May 12, 2018 at 7:22 AM
    Billy1234
    William
    2011 jeep wrangler
    None yet
    Parts are like 6 months old plugs wire n everything I’ll get the codes up inna few minutes. I’m in the middle of putting in a bay window inna house lol
  8. May 12, 2018 at 7:24 AM
    I will ck later -
    Did you use correct plugs? lots of aftermarket plugs are problematic.
  9. May 12, 2018 at 7:55 AM
    Billy1234
    William
    2011 jeep wrangler
    None yet
    I used the plugs that are recommended don’t normally like aftermarket plugs
  10. May 12, 2018 at 8:09 AM
    Good - I think Champion is OEM and - explain later.
    do you have a scanner - live data?
    Try a free scan at the auto part stores...
  11. May 12, 2018 at 8:16 AM
    Billy1234
    William
    2011 jeep wrangler
    None yet
    I have my super chip I bought with that cake with Jeep it has the codes in it
  12. May 12, 2018 at 8:26 AM
    the super chip is this a performance chip AKA pos?
    OK here is my thoughts/plan, we would correct the cause for the P0430, why I asked if its stock.
    FYI cats are warranted for 8yrs you MAY be in that window. And letting jeep have at it.
    BUT We need it stock for that avenue AND Super Ship wont work. You are modified. Good by warranty.
    And for a DIYer repair a scanner is needed to see live data see reply #6.
  13. May 12, 2018 at 9:59 AM
    Billy1234
    William
    2011 jeep wrangler
    None yet
    Flashpaq F5 is what it is
  14. May 12, 2018 at 11:18 AM
    set the jeep tune to stock.
    do not change tire or gear if it was re calibrated.
    Copy ALL codes showing - post here.
    we will go from code list
  15. May 12, 2018 at 11:28 AM
    Billy1234
    William
    2011 jeep wrangler
    None yet
    8110ABDE-3273-4C66-B539-9C61DC8B1700.jpg 34EE3719-1294-4B04-A21F-502BCFB71831.jpg C2487F35-323A-40A0-8285-394F87E1F3AC.jpg 85B7DBBD-6584-466A-9472-6597FCBA1CAA.jpg There’s a couple more codes but that’s from the new led headlights. but that’s what I have pop up
  16. May 12, 2018 at 12:31 PM
    every reply is a reveal - a POS programmer, p0300, cruise control, exhaust, and NON OEM LEDs.
    Any chance the exhaust has been F'ed with?
    Any exhaust leaks?
    Will programer read live data ie B2S1 o2 voltages?
    Is the ABS or traction control on light - is it coming on @2seconds at every start for bulb check?
    I am looking for a TSB while you reply.
  17. May 12, 2018 at 12:35 PM
    Billy1234
    William
    2011 jeep wrangler
    None yet
    Stock exhaust no leaks in it. abs and traction control come on like normal when starting the car then shut off right after. And no the filter is stock don’t use k&n.
  18. May 12, 2018 at 12:56 PM
    All the easy ones are being dismissed -
    I think the p0300 p2098 and p0430 are related. a multi misfire, and post cat o2 sensor readings issues.
    The LED issue self inflicted, the Cruise control with the easy ones dismissed will be a wire check not a priority.
    Ideally we want to look at fuel trims and the o2sensor voltages- that will let us see a mixture issue, fuel compensation, and sensor range - lean or rich... Now how to do without a scanner...
    will Post an idea later...
    PO579
    Possible Causes
    (V71) S/C SIGNAL 1 CIRCUIT SHORTED TO VOLTAGE
    (V71) S/C SIGNAL 1 CIRCUIT OPEN
    (V937) S/C SWITCH GROUND CIRCUIT OPEN
    (V71) S/C SIGNAL 1 CIRCUIT SHORTED TO GROUND
    (V71) S/C SIGNAL 1 CIRCUIT SHORTED TO THE (V937) S/C SWITCH GROUND CIRCUIT
    CLOCKSPRING
    SPEED CONTROL SWITCH
    POWERTRAIN CONTROL MODULE (PCM)
  19. May 12, 2018 at 1:04 PM
    I see that superchip MAY show live data - I saw owners manual page 24 --advanced - check into that
    this will show all if it is available.....:)
  20. May 12, 2018 at 1:05 PM
    Billy1234
    William
    2011 jeep wrangler
    None yet
    I’ll look in to that now idk if mine will I bought the basic one
