Squeaky clutch and stearing
Discussion in 'Wrangler TJ (1996-2006)' started by Kingbadass123, Jun 15, 2017.
  1. Jun 15, 2017 at 7:59 AM
    Kingbadass123
    Kingbadass123 [OP] Member
    Mavik
    1997 Jeep Wrangler tj Sahara 4.0 inline 6
    Rapids change underglow controlled via Bluetooth connection with phone skyjacker 4.5 inch lift nitriousfilled shocks 33 inch micky Thompson tires on amarican force wheels one 1200 watt 12" sub woofer green halo head lights full steal bumper badlands 12,000 pound winch k,n high performance air intake new manga flow exhaust system and a mud jack attached to the hood
    I need help my clutch has been squeaking for the longest time and it only does it after heavy use when I start it in the mornin it dose t do it but after all day of use it begins to squeak it's not burnt out I checked the pads and everything and it's still soft but it just squeaks. Also I tried spraying it with grease on the shaft and the actual clutch itself and it still does it. I am also getting squeak whenever I do a tight turn and ideas
  2. Aug 12, 2017 at 7:39 AM
    offroadjeep
    offroadjeep New Member
    WD-40? lol
  3. Aug 12, 2017 at 6:52 PM
    :boink:
    Sorry kingbadass. Last stick I drove was 25 years ago. And I know manual transmissions and clutches have changed. But I'm sure some one will jump on soon and help.
    Offroadjeep. :cheers:
  4. Aug 12, 2017 at 7:16 PM
    Not so sure about spraying grease on the actual clutch itself but check the pressure plate, throw out bearing for wear. Been muddin? Or deep waterin?
  5. Aug 12, 2017 at 7:21 PM
    Awesome aggrex. Since I "shelter" my JK. Never thought of that. Great point. Good to see you still have it after 20 years being without a Jeep. It's ok....i still look up to you. :proposetoast:
  6. Sep 5, 2017 at 10:27 AM
    Kingbadass123
    Mavik
    Mine is a 97 and I have put it under after but that was 3 years ago and the squeaking started recently
