Stalling
Discussion in 'Wrangler JK (2007-2017)' started by Casmer, May 19, 2022.
  1. May 19, 2022 at 1:41 PM
    Casmer
    Casmer [OP] New Member
    Albert
    2013 Wrangler
    2013 Wrangler stalls at traffic lights but only when ac is running. Dealer replacing a crankshaft sensor. Any thoughts? TY
  2. May 19, 2022 at 8:38 PM
    Groundfault
    Groundfault Well-Known Member
    Tim
    87 Wrangler, kind of...
    Faulty CPS usually sets an engine code (check engine light), rough idle, stalling, hard start. Doesn't fix itself and run fine when you turn the AC off. Dealership may have scan info or other reason to believe the CPS needs replaced.
    Make sure that your AC compressor isn't cycling because it's low on Freon. Short cycling screws with the signal to make IAC increase idle when the AC compressor kicks in.
    Keep us posted if you find solution.
