Sunroof leaks driver side
Discussion in 'Cherokee' started by nofear, Oct 21, 2019.
  1. Oct 21, 2019 at 12:54 PM
    nofear
    nofear [OP] Member
    Silver 2008 Grand Cherakee Laredo
    K & N intake
    Man , Hit by the N named storm last weekend and found my driver floor saturated. Took off the stancheon trim and tried to fish up to sunroof drain but I cant find the drain hole up top. Is there any access to the drain hole topside?
  2. Oct 21, 2019 at 2:21 PM
    A sunroof with a leak - who would have thought...
    diagram any help?
  3. Oct 21, 2019 at 3:20 PM
    Some had some success with blowing air into the drain lines. Removing the headliner could become a total FUBAR.
  4. Aug 7, 2020 at 12:37 AM
    nofear
    nofear [OP] Member
    K & N intake
    REMOVE FRONT VISER ,1 at a time, 2 SCREWS AND REACH IN AND PULL OFF TUBE then fish 14 guage wire on the holr to clear debris. run water slow into hole to check for exit at bottom of frame. try same on other side if nescessary.
