Sunroof opened all the way, won't close.
Discussion in 'Grand Cherokee' started by Woodsie, Aug 10, 2023.
  1. Aug 10, 2023 at 1:18 PM
    Woodsie
    Woodsie [OP] New Member
    2013 Jeep Grand Cherokee
    Hi, My 2013 Jeep Grand Cherokee sunroof won't close. I checked the fuse, it sounds like like the motor is working g when I hit the switch, I checked for debris in the tracks and I swapped out the overhead control with another Jeep and that works. Any help from someone would be greatly appreciated.
  2. Aug 10, 2023 at 7:29 PM
    "I swapped out the overhead control with another Jeep and that works"..........problem solved?
  3. Aug 11, 2023 at 3:35 AM
    Woodsie
    Hi, sorry, the rest of my post was somehow deleted, swapping the overhead control didn't work either.
  4. Aug 12, 2023 at 12:15 PM
    shooter65
    shooter65 Well-Known Member
    Southwest PA
    2023 Rubicon 4 Door
    Probably not the same but I had a 2006 Charger with a similar issue. IIRC the fix was to pull the fuse to the sunroof, have my wife push the button to close it while I put the fuse back in. As soon as I put the fuse in the sunroof closed all the way and worked perfect for years after.
    Hope it's that simple.
