Tappet rattle.
Discussion in 'Wrangler JK (2007-2017)' started by KIWI57, May 15, 2022.
  1. May 15, 2022 at 10:51 PM
    KIWI57
    KIWI57 [OP] New Member
    2016 White jeep wrangler sport
    Bull bar, winch, tow bar and larger wheels
    Has anyone had a tappet rattle on 3.6 l motor. Thanks in advance.
  2. May 19, 2022 at 5:19 AM
    tomrr
    tomrr Well-Known Member
    Tom
    2012 Wrangler JK
    No, But try add some Marvel Mystery Oil next oil change. I have been using if for 50 years in every thing I own. Can't32602593_1664892756909825_8191468013271121920_n.jpg hurt.
    KIWI57 [OP] likes this.
  3. May 19, 2022 at 5:27 AM
    Groundfault
    Groundfault Well-Known Member
    Tim
    87 Wrangler, kind of...
    Ticking noise can be caused by a bad lash adjuster (hydraulic self adjusting lifter) or a bad rocker. They're not solid lifters (tappets) and there's no manual lash adjustment on them. Not uncommon in the 3.6L. Sometimes lash adjuster noise will go away with fresh oil and filter (or a little Marvel Mystery Oil). Low oil pressure can make them tick and dirty oil can clog the adjuster. Worn rockers are also pretty common. Bad rocker can cause excessive wear on it's lifter, or rocker wear from bad lifter. They're easy to change once you finally get to them, so I'd change them as a set while you're in there.
    aggrex and tomrr like this.
  4. May 19, 2022 at 6:56 PM
    KIWI57
    Thankyou.
  5. May 19, 2022 at 7:00 PM
    KIWI57
    Thanks. It was a rocker failure. Having new lifters and rockers.
    aggrex, tomrr and JKBob 25 like this.
