TJ nofuse error
Discussion in 'Wrangler TJ (1996-2006)' started by TJ4me, Sep 3, 2019.
  1. Sep 3, 2019 at 8:30 AM
    TJ4me
    TJ4me [OP] Active Member
    2001 Jeep Wrangler Sahara
    I have a 2001 TJ that just started popping a "nofuse" error on the odometer. I have rung out all the fuses ( hood and behind the glove box ), checked as much of the wiring harness as possible, pulled all the bulbs out of the dome, cabin and hood lights, disconnected the radio and still get the error. She starts and runs great. I'm stuck. Battery dying? Any ideas?
    Thanks...
  2. Sep 3, 2019 at 8:33 AM
    Welcome @TJ4me ...try disconnecting battery for a few minutes? Scan for codes?
  3. Sep 3, 2019 at 10:14 AM
    welcome to the forum - enjoy the camaraderie - hope we can help :jeepwave:
    OK did you check OR just look at the fuses?
    Any recent work done esp ELECTRICAL - anything plugged into outlets (lighter cigar) - double check #15 in PDC.
    Also check* IOD fuse in diagram advise
    do not look check fuses!!
  4. Sep 3, 2019 at 10:31 AM
    TJ4me
    Hi-
    Thanks for the reply!
    I used a multi-meter to test the fuses including the IOD fuse. I tried a spare IOD fuse just for the heck of it...
    What is number 3 in your diagram above?
  5. Sep 3, 2019 at 12:20 PM
    #1 IOD fuse
    #2 IOD storage ( when removed)
    #3 is your PDC -
  6. Sep 3, 2019 at 6:29 PM
    TJ4me
    Ugh...
    I disconnected the off-road lighting. Then disconnected the battery for a reset. I can’t do a scan because that circuit is tied into the problem circuit. I don’t have an IOD storage fuse socket.
    Thanks for all the ideas!
    Really appreciate the help!
    I just bought a circuit tester light. I thought I would start ringing out each circuit to see what happens.
    I’ll let you know...
    Any thoughts that it might be the battery?
  7. Sep 3, 2019 at 7:10 PM
    I'm confused ---happens alot ---
    Why can't you scan?
    which circuit is the problem circuit?
    Stop removing battery needlessly.
  8. Sep 4, 2019 at 5:58 AM
    TJ4me
    Could be an unrelated issue, but there is no power at the connector when I attempt to scan.
    The problem circuit is the IOD. The gauges, radio, interior and under hood lights are all affected.
  9. Sep 4, 2019 at 7:07 AM
    no coffee yet = no fuel But my 1st thought ...IOD fuse is good (meter confirmed) I suspect then an open in circuit... And there is a memory synapse something in memory trying to open...
    Did you check your Cigar lighter - is that getting 12v?
  10. Sep 4, 2019 at 6:21 PM
    TJ4me
    Thanks for sticking with me on this.
    Yes. I get 12 volts at the cigarette lighter. But I think it is a different circuit than the IOD circuit because it is switched through the ignition...
    I'm thinking it has to be an open in the harness someplace. I'll start tracing it out this weekend when I have some time...
    Thoughts?
  11. Sep 4, 2019 at 7:22 PM
    I suck at electrical issues. But I'm subbed. :popcorn:. Hopeing I might learn me some stuff here. :coffee:.
  12. Sep 8, 2019 at 4:59 AM
    TJ4me
    Problem solved!!!
    I disconnected the positive battery lead from the fuse box under the hood. Then, I removed the bottom case from the fuse box and started checking the wires relating to the IOD circuit. Specifically, the pink wire with white stripe. They looked good. However, I found the wire was burnt about six inches away from the fuse box just as it entered the harness wrapping down beside the battery.
    I cleaned up the wire and butt-spliced it together. Everything is working again!
    Thank you, everyone for your help!
  13. Sep 8, 2019 at 6:06 AM
    I am confused - weekends do that - BBQ, Bourbon, FOOTBALL!! and we spotted a brood of turkey on corner of property!! SO not today but will help if you reply
    Electrical come easy to me - do a lot of troubleshooting at shop.
    What leads you to focus on IOD fuse and circuit?
    What are symptoms -
  14. Sep 9, 2019 at 6:17 AM
    TJ4me
    I focused on the IOD circuit because of the "Nofuse" error I was getting on the odometer. Also, the interior lights and the radio would not work.
    The IOD fuse was good, so I knew it had to be an open somewhere.Luckily, I found a burnt wire below the fuse box under the hood. I repaired it and it did the trick!
    Thanks for your help!
  15. Sep 9, 2019 at 6:53 AM
    Thanks for reporting back with your resolution. It seems many don't and when someone starts searching they find that others have had their problem but nobody posted if it got fixed and what the issue was.
  16. Sep 9, 2019 at 10:53 AM
    TJ4me
    73s from a fellow ham !
  17. Sep 9, 2019 at 10:59 AM
    EXCELLENT!
    Have a setup in your Jeep?
    73 to you as well!
  18. Sep 9, 2019 at 3:54 PM
    Good find, but why did it burn?
  19. Sep 9, 2019 at 5:08 PM
    TJ4me
    73 to you as well!
    No permanent rig...Just a handheld...
    I'd be interested in what you are using for an antenna and mount...
  20. Sep 9, 2019 at 5:14 PM
    TJ4me
    The previous owner attached a set of off road lights ( non-fused ) to the IOD circuit.
    It must have drawn too much current when I turned them on and burnt the wire.
    I put an "add a circuit" on an existing circuit so it won't happen again...
