Transmission shift issues
Discussion in 'Cherokee' started by Skeeter1, Sep 30, 2020.
  1. Sep 30, 2020 at 3:58 PM
    Skeeter1
    Skeeter1 [OP] New Member
    bob
    1995 jeep cheokee sport 2wd 4.0 automatic
    I own a 1995 Cherokee Sport 2wd automatic transmission shifted fine I detailed the engine compartment and now I have a hard shift to 2nd gear (only a high rpm) and a no shift to 3rd. I changed the filter and replaced all 3 solenoids but still won't shift I reset the shift cable still does not shift. Any suggestions
  2. Sep 30, 2020 at 4:27 PM
    Hello Skeeter, welcome from Oklahoma.
    I'm sorry I don't have any definitive answer but it seems like you may have knocked a sensor loose when you sprayed down the engine bay. Did you spray under the vehicle too?
  3. Sep 30, 2020 at 5:13 PM
    Skeeter1
    bob
    No I did not clean under the vehicle could it be the PCM or TCM
