Turn Signals Gone Wild! (& other electrical oddities)
Discussion in 'Grand Cherokee' started by Jmac Jeep, Nov 12, 2022.
  1. Nov 12, 2022 at 10:55 AM
    Jmac Jeep
    Jmac Jeep [OP] New Member
    2002 Jeep Grand Cherokee
    I have a 2002 Jeep Grand Cherokee. After I replaced the power window motor (every two years...Thanks Jeep!), my turn signals and air system (heat/AC) stopped working. Turns out fuse #20 was fried. Popped in a new fuse and the turn signals are back! BUT, the air still doesn't work. AND, now the turn signals only work when the car is in Drive. Ha! There's definitely an electrical issue at play. Any thoughts/suggestions are greatly appreciated! Thank you!
    *UPDATE*
    Just checked, fuse 20 (air system and turn signals) is blown again, BUT turn signals still work when car is in Drive. To test, I put in a new fuse and -pop- on start up. Something is causing a short.
  2. Nov 12, 2022 at 8:44 PM
    Before replacing the fuse again the issue causing the short needs to be found. Could be rodent damage or failing component or wires.
    LYFZGOOD likes this.
