Upgrading everything
Discussion in 'Wrangler TJ Builds (1996-2006)' started by Zacho13, Nov 28, 2017.
  1. Nov 28, 2017 at 7:39 AM
    Zacho13
    Zacho13 [OP] Member
    Zach
    Freehold New Jersey
    1997 Green Wrangler Sport
    4 inch lift 50" Lightbar 2 lightbar pods 8500 lbs winch on aftermarket bumper 33" all terrain wheels
    so I am currently running 31” wheels on Dana 33 axels with a stock gear ratio and a 4” lift. I want to run 37s or 40s and I need to upgrade my axels and gearing and I don’t know what else I need to do or have what parts do I need and what do I actually need to do to really upgrade everything
  2. Nov 28, 2017 at 8:13 AM
    You more likely have Dana 30 front axle and a Dana 35 rear axle.
    The Dana 30 could live with 35"s, and with a super30 or chromoly axle shafts it could likely handle 37"s and maybe 40"s though that may be pushing it.
    The Dana 35 rear, though there are upgrade kits available it is often referred to as polishing a turd. If you could find a Dana 44 that you could upgrade it should be able to handle 37"s.
    But price all that out and compare to a set of 1 ton axles, see which one is more cost effective for you.
  3. Nov 28, 2017 at 8:19 AM
    If you run a Highline/overline fenders like poison spyder's or my favorite metalcloaks you can run 38s with your current 4 in lift. Do you have a Dana 35 or 44 in the back? You most likely have a Dana 30 up front. My buddy has an LJ with Dana 44 in the back and Dana 30 up front, 4in lift and 37x12.50x15s on his and he does very well offroad. It is really how much do you want to spend. You can beef that Dana 35 up, but I bet you could find a used Dana 44 out of a TJ/LJ for not much more. The dana 30 is pretty stout up front, and you could build it up as well. I bet you could find a TJ/LJ Rubicon front Dana 44 for $800+\-. Here is a picture of my buddy's LJ with Dana 44 back and Dana 30 front with RCV axle shafts (best on the market) 37s on a 4in lift. He does rub a little under full flex as he sits.
