Washer fluid issues
Discussion in 'Wrangler YJ (1986-1995)' started by OrangecrateYJ, Sep 14, 2021.
  1. Sep 14, 2021 at 5:29 AM
    OrangecrateYJ
    OrangecrateYJ [OP] Member
    Kim
    1995 orange YJ
    3 inch lift, wheel spacers
    Hello again
    I have a 1995 yj 2.5
    My wipers work when turned on with both speeds but when I try to use my washer fluid nothing works no washer fluid no wipers
    Is there a special fuse that runs those or am I missing something?
    Thank you for any help/advice
  2. Sep 14, 2021 at 9:27 AM
    when you use front washer no washer AND wipers stop?
    Sounds like a problem with multi-function switch. Before spending $$-
    I would unplug multi function switch 7 wire connector- unplug washer pump. Check to see if washer pump circuit is grounded- brown wire.
  3. Sep 14, 2021 at 9:38 AM
    OrangecrateYJ
    Kim
    1995 orange YJ
    Yes when I turn my switch on for front wash nothing works no wipers or wash
    Thank you I’ll definitely try this before spending money and I’ll post with an update
