Welder
Discussion in 'General Jeep Discussion' started by Adam39601, Nov 2, 2017.
  1. Nov 2, 2017 at 2:03 PM
    Adam39601
    Adam
    2001 jeep wrangler sport
    Got a question, going to get a wire welder . what's everyones opinion on what is better gas shield or flux core. Need one to work on the anti Christ in my shop.
  2. Nov 2, 2017 at 2:26 PM
    boondoc89 Well-Known Member
    GAS SHIELD ALL DAY EVERY DAY!!! flux core is a massive pain in the ass if you don't have all your settings perfect. When you have gas it allows for a little more room for error if you're not an every day welder. So if you're gonna spend the money buy a quality welder that has a decent duty cycle. Anything 40% or higher duty cycle will be more than enough to work on just about anything in a garage.
  3. Nov 2, 2017 at 5:18 PM
    I have a millermatic 211. Love it. Does both flux and mig. Mig is much easier and cleaner. Miller also has one that will do all flux mig stick and tig. You just have to get all of the accessories.
