What did I break?
Discussion in 'CJ' started by JohnnyRotten, Aug 22, 2017.
  1. Aug 22, 2017 at 8:27 PM
    JohnnyRotten
    JohnnyRotten [OP] Member
    I am in the process of replacing the driveshaft in my CJ with a double cardon shaft. I took the old yoke off and installed the new one. Had a little trouble getting it to seat so I whacked it with a 4x4 a couple of times. Yeah I wasn't thinking at all. I didn't hit it that hard but now my output shaft has a lot of play back and forth. What did I damage? What do I have to do to fix it. Live and learn I guess.
  2. Aug 22, 2017 at 8:39 PM
    Holy crap. Your in luck. We have a great drive line guy. The best hereee by far. I think he's resting from the grilled cheese sands he ate. A lactose thing I assume. Lol..But he'll check in. Hold tight dude.
    jharris3 likes this.
  3. Aug 22, 2017 at 9:32 PM
    JohnnyRotten
    Well I am hoping it is a simple fix. I have another Dana 20 if it isnt. Its just I am doing a frame replacement so of course everything is painted and clean....the other Dana is not.
  4. Aug 23, 2017 at 6:48 AM
    :bowdown:
  5. Aug 23, 2017 at 6:48 PM
    Sounds like you seperated the bearings when you whacked it. Dissasemble, press off old bearing off of the output shaft, press on new bearing and reassemble. I have been inside the dana 20 a couple of times, and I feel it is a pretty simple setup for those that are mechanically minded. If it was me Id try to drive it like it is before I went to the trouble of rebuilding it.
    Really no whacking.
  6. Aug 23, 2017 at 6:53 PM
    There he is. What took ya so long OFFGRID? A member needs you. Lolll.
    Really no whacking. ok, I'm going to leave that one alone. Well.....for now anyway. o_O
    JeepMafiaMama likes this.
  7. Aug 23, 2017 at 6:55 PM
    Sweet...nice work.
  8. Aug 23, 2017 at 10:43 PM
    JohnnyRotten
    Thanks for the answer and the compliments.Before this tear down I added power brakes, and a hydraulic clutch. During this down time I put the headlights on relays, added a True Trac to the Dana 44. Attempting to go TBI. Stainless brake lines, tie rod flip, and a double cardon drive shaft. Also have a Cougar fan and a Volvo fan relay to work into the mix. I started back in November but the garage is too cold. Once I got it tore down to the frame I was pretty much banished till it started warming up in the spring. Here are a few more pics of my project:
    aggrex, JKBob 25 and OFFGRID like this.
  9. Aug 24, 2017 at 3:27 PM
    Another TDK fan. Awesome!
  10. Aug 24, 2017 at 6:19 PM
    Where do you live? Need any more friends? Between you and OFFGRIDS builds and rebuilds.I'd love to help on any. Lol.
  11. Aug 25, 2017 at 10:14 AM
    JohnnyRotten
    OHIO, well I took the back off the Dana 20. By hitting the yoke with a 4x4 what I did was push the shaft out of the rear bearing. I took the seal out and used some PVC to tap the bearing back onto the shaft. Put a new seal in it and re-installed the bugger. The new yoke had a dust shield that would not fit over the snout on the back of the TC. The old shield would not fit over the step on the new yoke. Well a BFH and some 2" PVC cured that. It was thin enough to form around this step. I put it all back together and used the nut to seat the yoke this time....lesson learned.
  12. Aug 25, 2017 at 6:38 PM
    Ahh....to far of a drive. Lol. But hey, keep posting. I'm subbed. Looks like fun.
  13. Jun 16, 2019 at 10:42 AM
    CorKen
    CorKen New Member
    1984 Jeep CJ7
    Nice Jeep! What engine and transmission do you have in it?
  14. Jun 16, 2019 at 11:52 AM
    Welcome @CorKen ...What's your CJ story? Post a intro thread with a few pics
  15. Jun 18, 2019 at 12:07 PM
    What will @JKBob 25 do if whacking is not allowed?
  16. Jun 18, 2019 at 1:03 PM
    Let’s be thankful that activity is not tolerated in public areas. Now out in the boondocks miles away from the border anything is fair game.
    TJ_abuser[QUOTED] likes this.
