Where to buy a Lift Kit for my Jeep Wrangler
Discussion in 'Wrangler YJ (1986-1995)' started by pappadoooos, Nov 6, 2017.
  1. Nov 6, 2017 at 1:07 PM
    pappadoooos
    pappadoooos [OP] New Member
    ja
    1989 Jeep Wrangler YJ
    I recently purchased an 89' Jeep Wrangler YJ and I want to lift it 6 inches. I've only found 1200.00 lift kits online. Is that typical pricing for a lift kit on this Jeep. Also, should I do a body lift or suspension lift. I'm not really sure what steps to take first.
  2. Nov 6, 2017 at 1:39 PM
    That is what I am seeing as well, however you might look at a Spring Over Axle (SOA) lift that uses the stock leaf springs but moves the axle from being on top of the springs to below the springs. This adds about 6-6.5" lift and keeps the stock ride quality. http://www.rocky-road.com/yj-soa.html
    with that much lift you will likely need a Slip Yoke Eliminator and a new rear driveshaft.
  3. Nov 6, 2017 at 1:59 PM
    Welcome to the site !
  4. Nov 6, 2017 at 4:10 PM
    Welcome! Nice choice for build vehicle. Lots of aftermarket lift choices for the YJ out there.
  5. Nov 6, 2017 at 5:01 PM
    Yep. Prerunner has it right. The SOA lift from rock road is the best lift on the market. If you are running the factory springs your ride will be excellent. Their instructions are horrible. Hope you're good at figuring out things on your own. Also you will want to run a 5 leaf factory spring pack in the front in order to prevent axle wrap and you will need to make a custom spring pack out of factory 5leaf and 4leaf to prevent axle wrap in the back. When you get to this point hit me up and I will point you in the right direction for the instructions on how to build the rear springs.
    Prerunner1982 and JKBob 25 like this.
  6. Nov 6, 2017 at 6:50 PM
    Welcome to the forum pappadoooos.
    You came to the right place. Your in good hands with these guys. Look forward to your build.
