Where to mount aux light rocker switches?
Discussion in 'Wrangler TJ (1996-2006)' started by Jesro, Jan 31, 2017.
  1. Jan 31, 2017 at 12:13 PM
    Jesro
    Jesro [OP] New Member
    Jesse
    Pensacola florida
    05 tj unlimited
    3in lift,1inch body lift. 33s on 12.5 rims, best top, kc lights.
    Looking for ideas where to mount aux. Light rocker switches. Any body?
  2. Feb 1, 2017 at 2:29 PM
    I mounted mine on the "A" pillar. Instead of using an aftermarket switch housing, I drilled and installed my slef.
  3. Feb 1, 2017 at 4:18 PM
    Rc Jeep
    Rc Jeep Well-Known Member
    Ryan
    '16 Rubicon
    I just installed an sPod, so far I really like it. It mounts over the rear view mirror. The switch panel is all pre wired to plug into their fuse box. Meaning that you only have to cross the firewall 1 time for the pre wired switches, after that all accessories wire to the fuse panel and are ready to go.
    chris4x4, OFFGRID and Bob like this.
  4. Feb 1, 2017 at 4:33 PM
    Pictures please. Thats sounds cool.
  5. Feb 1, 2017 at 5:28 PM
    Rc Jeep
    Ryan
    '16 Rubicon
    Fuse block.the harness in the front of the photo is the only wore that crosses the firewall. It has a positive and a negative pigtail that connect direct to the battery. The panel will cut power to everything hooked up if your battery drops do 12.6v
    Switch panel. The center cut out is for a Genesis g screen dual battery monitor.
    Night view of the switches. They are dual led lit. I turned several to the off position to see the dual led. I a not bought the labels for the switches yet.image.jpg
    OFFGRID[QUOTED] and chris4x4 like this.
  6. Feb 1, 2017 at 7:35 PM
    Wow! Looks really clean.
  7. Mar 18, 2017 at 8:33 AM
  8. Mar 18, 2017 at 8:38 AM
