Which tires and rims before adding 3" lift to my Jeep Commander?
Discussion in 'Wheels & Tires' started by Username, Jul 28, 2021.
  1. Jul 28, 2021 at 6:45 AM
    Username
    Username [OP] New Member
    Colin
    2006 jeep commander
    What tires and rims should get before adding a 3" lift to my 2006 jeep commander?
  2. Jul 28, 2021 at 1:19 PM
    Groundfault
    Groundfault Well-Known Member
    Tim
    87 Wrangler, kind of...
    You should probably do the 3" lift first so you can verify new tire clearance. You might also have to add wheel spacers to get tires to clear upper ball joints. 3" lift kits or spacer lifts vary depending on brand and can give you more or less than 3".
  3. Jul 28, 2021 at 6:38 PM
    @Groundfault is correct….nobody buys big shoes to grow into. Post up your lift installation and we will help select a wheel/tire combo
    LYFZGOOD likes this.
