Will a 275/65r18 fit on a grand Cherokee with no lift
Discussion in 'Grand Cherokee' started by 2020girlgrandcherokee, Aug 22, 2021.
  1. Aug 22, 2021 at 5:23 AM
    2020girlgrandcherokee [OP] New Member
    Joyce
    2020 Jeep Grand Cherokee Laredo
    Thinking about changing my tires and rims on my Jeep Grand Cherokee want to go aggressive just a lil but will a 275/65r18 tire fit without rubbing or will i need a lift tires are Bridgestone Dueler A/T
  2. Aug 22, 2021 at 7:05 AM
    The 275s will be 1.5+” taller than the stock tires and the width is only 0.4” wider. There could be some rub up front. Take a few measurements as the bigger tire on the stock wheels will be approximately 3/4” closer to any potential rub spots like strut towers, splash guards etc. The speedo will be off by about 3mph
  3. Mar 4, 2025 at 2:04 PM
    rdsk
    rdsk New Member
    2018 Red JGC TH v6 3.6L Stock
    For others finding this thread... I was curious of the brand of tire makes a difference as a Tire Size calculator I use says the difference is 1/2 inch in height and the same 0.4in in width.
  4. Mar 5, 2025 at 3:46 PM
    Different tire brands can make a difference in situations of tight or limited wheel well or fender clearance. If your specifications are on point the 1/2'' in height should not have any issues.
