Will a cam sensor cause
Discussion in 'General Jeep Discussion' started by rapracing, May 16, 2017.
  1. May 16, 2017 at 12:21 PM
    rapracing
    rapracing [OP] Member
    a Misfire on Cylinder One (ONLY) Code?
    P301
  2. May 16, 2017 at 2:46 PM
    Possibly the injector. Before buying a new one I would try to clean the current one. I often hear about people replacing coil, spark plug, and plug wires when it turns out all along it was the injector. Try swapping a coil, plug and wire from a known working cylinder and see if you still get the same code. If so it is likely the injector. Anybody else have any thoughts.
  3. May 16, 2017 at 7:29 PM
    Had a buddy have the same issue with a misfire in a Chevy Pick Up. A mechanic friend of his told him it could be one of a dozen things. I told him to throw a bottle of injector cleaner in the tank. Ran the truck for 15 minutes. And the misfire stopped. Start with the cheapest easiest fix. And go from there.
    I would also follow the advice of OFFGRID. Peter knows his s--t. :bowdown:
