WJ lift, is it worth it?
Discussion in 'Grand Cherokee' started by 66&99jeep, Oct 6, 2022.
  1. Oct 6, 2022 at 5:07 PM
    66&99jeep
    66&99jeep [OP] New Member
    good evening all, new to the site. To get down to the question, I recently came across a 99 Grand Cherokee WJ limited with AWD. it's in relatively good shape (I live in Iowa so it does have some salt cancer on the underside). basically I would like some input or suggestions on a 4" lift. what do i need to take into consideration and for most, is it worth it? would appeciate any input. thanks
  2. Oct 6, 2022 at 7:04 PM
    If the 4" lift gives you the look and functionality you desire then by all means get it done but inspect the Jeep completely to make sure the rust on the underside is not excessive, limited and repairable. With any lift expect decreased mpg, handling, towing etc.
    Dirty Dog likes this.
  3. Oct 7, 2022 at 9:41 AM
    Dirty Dog
    Dirty Dog Well-Known Member
    Mark
    2011 & 2013 JKU Rubicon
    If you're going for the look, then go for it.
    If you're planning to take it off-roading, then you need to understand that AWD is not the same as 4WD. I suspect your vehicle is 4WD, not AWD.
    With the lift, I assume you're also going to be swapping on bigger tires. So another factor to keep in mind is that the Dana 30 in the front of the WJ is not particularly robust. If you're building a rig to look cool, it will probably hold up. But if you add lockers or any sort of HP increase, you can expect it to fail.
