XJ shuts off at the most random of times
Discussion in 'Cherokee' started by Billy1234, Dec 27, 2019.
  1. Dec 27, 2019 at 12:58 PM
    Billy1234
    William
    1997 XJ 2 door
    None yet
    So I got the xj done and inspected. This xj is 1000% stock. I did a engine swap of same engine from my 2 door. Starts up perfect runs amazing then dies while driving. I'm not sure on what it could be besides maybe a fuel filter just a guess. There are no codes what so ever.
  2. Dec 27, 2019 at 3:10 PM
    I believe you are having an issue with the cam sensor or crankshaft position sensor. No codes will be sent, the issue can get worse until it won't run anymore.
    JKBob 25 and Billy1234 [OP] like this.
  3. Dec 27, 2019 at 3:35 PM
    Billy1234
    William
    1997 XJ 2 door
    None yet
    Thank you I will change both tommrow and give an update
  4. Dec 27, 2019 at 5:36 PM
    I cases that I have seen, the crankshaft sensor goes bad first. I would think by now it has already been replaced. It is located on the upper drivers side of the bellhousing. the cam sensor should be located in the distributor. I had a cps go bad with the same symptoms and from what I have heard the cam sensor issues are the same.
    aggrex, JKBob 25 and Billy1234 [OP] like this.
  5. Dec 29, 2019 at 5:22 PM
    This happened in my ex-XJ numerous years ago. It turned out to be the cam sensor.
    Any progress @Billy1234 ?
  6. Mar 24, 2020 at 8:26 PM
    Blacknoblue
    Blacknoblue Member
    1996 Cherokee sport 4.0
    Mine is a 96 xj.
    Same issue before.
    Manifold Pressure Sensor.
  7. May 31, 2021 at 7:47 PM
    Johndrown0316
    Johndrown0316 New Member
    John
    95 jeep cherokee sport 4 door
    Having a similar issue with my 95 xj. Replaced everything ignition wise and still not getting spark. Can the cam sensor play a part in this issue? Ive replaced the crank sensor already. Please help!!
