Zj gauge cluster issue
Discussion in 'Grand Cherokee' started by Zuzukadoo, Jan 27, 2024.
  1. Jan 27, 2024 at 7:24 PM
    Zuzukadoo
    Zuzukadoo [OP] New Member
    98 jeep zj 5.2
    Ay I was was just seeking some advice I'm having this crazy issue with my zj with the 5.2. It runs really great except my whole dash cluster wont work including odometer all of. Iv went to junk yard picked up two other cluster still no luck also checked all grounds including body grounds. So thennn I took a noid light and am only getting power on the violet wire at the connector for the cluster all doors windows work if some has a fix or an idea let me know I don't even care if it's redneck engineering as long as my gauges will work again thanks
  2. Jan 27, 2024 at 7:25 PM
    Zuzukadoo
    98 jeep zj 5.2
    Forgot to mention it failed the self test Also all fuses checked out
  3. Jan 29, 2025 at 2:46 PM
    Hip-Pea Fly Guy
    Hip-Pea Fly Guy Member
    Hippy
    Grand Cherokee ZJ
    Body Control Module. Under the dash, left side below the headlight switch. Last time it happened to me I bought a couple on ebay ~ 100.00 each. It's about a thirty minute swap out - didn't require any programing. Down side is your odometer will read whatever the donor had.
